small gpu problem
Go to solution Solved by MaxBunny,
7 minutes ago, chimado said:
small gpu problem
170mm
There are pills that can help you fix that. ( ͡° ͜ʖ ͡°)
15 minutes ago, chimado said:
i am upgrading my pc and i don't know which small gpu i should buy i am thinking 960 or 970 mini
It should be between the ITX 1060 (like http://www.newegg.com/Product/Product.aspx?Item=N82E16814125903 ) and...yeah, that. There's nothing competing with it yet for performance in that size range and price.
small gpu problem
170mm
https://linustechtips.com/topic/657785-small-gpu-problem/#findComment-8506015
i had no clue this gpu was a thing thank you so much
https://linustechtips.com/topic/657785-small-gpu-problem/#findComment-8506478
