1 minute ago, JohnnyCowboy1098 said:
I'm unsure about what ATX case to use, going for a blue and black theme. Suggestions?
Define S, NZXT S340, Corsair 400C, Phanteks P400 <- high value/dollar cases
Corsair 460x, Phanteks Enthoo Evolv Atx TG <- bling cases
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/657269-atx-case-recommendations/#findComment-8499705
1 minute ago, PillowFortEngineer said:
Yo is the 460x on the market already, i need me that sexy beast
Doesn't look like it. Should be in the next few days.
https://linustechtips.com/topic/657269-atx-case-recommendations/#findComment-8499854
3 minutes ago, PillowFortEngineer said:
FUCK, im buying my stuff tomorrow
Can always run your pc cardboard box style until you get it.
Or buy a 400C and mod the side-panel with window glass (not hard or expensive to do).
https://linustechtips.com/topic/657269-atx-case-recommendations/#findComment-8499925
is the 460x basically a 400c with a fron glass panel?
https://linustechtips.com/topic/657269-atx-case-recommendations/#findComment-8499939
And glass side panels. Yea. The internal is identical. The fans are different, but you can buy those separately.
https://linustechtips.com/topic/657269-atx-case-recommendations/#findComment-8499959
I need to learn how to mod a case like that, otherwise is an inwin case good enough?
As long as you like the looks. I'm a huge anti-fan of InWin and Lian Li cases because they sacrifice functionality to the aesthetics gods (without even looking that good imho.)
Almost any case is good enough...
My mod was literally take off the plastic panel, buy a piece of window glass, use black RV silicon to attach it, and GG.
You could obviously go closer to the edges, or have holes drilled in them instead if you wanted a border-less design.
https://linustechtips.com/topic/657269-atx-case-recommendations/#findComment-8500006
That is my main thing, I want borderless design, although i would literary need to cut the thing down. Is that window the same size as the stock but just with glass instead of plastic?
https://linustechtips.com/topic/657269-atx-case-recommendations/#findComment-8500028
Yerp. Makes it look really premium.
https://linustechtips.com/topic/657269-atx-case-recommendations/#findComment-8500038
