So i've been seeing price drops in the gtx 660 and I was thinking about buying one but, my mobo only supports crossfire, but it has 2 8x pcie slot so would hyper sli work with the latest drivers?
I am not sure, but I wouldn't risk it. Either drop the 660 for an AMD card or get a new mobo. That's what I did.
https://linustechtips.com/topic/65697-does-hyper-sli-work/#findComment-897544
Dahell is Hyper SLI?
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/65697-does-hyper-sli-work/#findComment-897547
It is some aftermarket software implication of SLI for motherboards that don't support it AFAIK.
https://linustechtips.com/topic/65697-does-hyper-sli-work/#findComment-897558
Google it, someone else has been bound to try it. Usually a board that supports Crossfire or SLI will support either regardless if they're stated or not.
I believe SLI can work on 8x/8x, just not below 4x.
Error: 410
https://linustechtips.com/topic/65697-does-hyper-sli-work/#findComment-897610
Boards with chipset below 900 don't support SLI, what board and CPU do you have?
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/65697-does-hyper-sli-work/#findComment-897907
