I'm building a new PC and I was wondering if I could get some community feedback on my choices for everything, I have two sticks of DDR5 memory which are both 8GB. The price on PC part picker is 481$ this is not including the graphics card. I found the same processor on amazon used for around 100$ which furthermore reduces the price.  Please leave your interesting or creative responses below, this is supposed to be under 500$ so I got pretty close to my budget.
https://linustechtips.com/topic/656400-first-pc-build/
Looks fine to me, but unless you get the CPU really, really cheap, I'd recommend at least getting a newer Haswell (i5-4xxx), if not a Skylake (i5-6xxx). (Haswell if the RAM you have is DDR3, Skylake if it's DDR4.)
An i3-6100 performs almost as well as the old i5-2500.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/656400-first-pc-build/#findComment-8484261
Thanks for the reply I have heard that an I3 runs really well actually too, if there is a very significant price difference I might try the i3 actually thanks
https://linustechtips.com/topic/656400-first-pc-build/#findComment-8484480
1 hour ago, Primevil5 said:
Just go for the i3 6100 and buy new RAM
Otherwise that PSU isn't a good buy
Far as the OS goes, someone had a guide on how to legit get windows installed for free, you just get the usual unactivated limitations
and get a 4 GB card no matter what you do
PCPartPicker part list: http://pcpartpicker.com/list/xBXmr7
Price breakdown by merchant: http://pcpartpicker.com/list/xBXmr7/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($110.99 @ SuperBiiz)
Motherboard: MSI B150M Pro-VD Micro ATX LGA1151 Motherboard  ($56.98 @ Newegg)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($32.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: Gigabyte Radeon RX 460 4GB WINDFORCE OC Video Card  ($127.99 @ SuperBiiz)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($35.99 @ SuperBiiz)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($62.99 @ SuperBiiz)
Total: $475.41
Generated by PCPartPicker 2016-09-07 15:22 EDT-0400
https://linustechtips.com/topic/656400-first-pc-build/#findComment-8484509
Edit** was gonna mention that the i3 is dual core so crysis 3 bf4 might not be great but I didnt know it did hyperthreading. So apparently its great ?
https://linustechtips.com/topic/656400-first-pc-build/#findComment-8485514
How does hyperthreading change the game of CPU's other than the cool name?
https://linustechtips.com/topic/656400-first-pc-build/#findComment-8489046
Well it means the i3 6100 is essentially a quad core so will run those games better at that low price point. But when I said apparently its great I was reffering to some positive reviews about that cpu. Apology for my confusing wording
https://linustechtips.com/topic/656400-first-pc-build/#findComment-8491423
Oh okay, thank you so much for your help, and advice!!
https://linustechtips.com/topic/656400-first-pc-build/#findComment-8494148
  • 2 weeks later...
The i3 6100 is pretty solid because of it's relatively high clock speeds and 4 threads ya, almost better than the i5 6400
https://linustechtips.com/topic/656400-first-pc-build/#findComment-8580162
