1 hour ago, WinNut said:
Quick question for you guys, are swipe barcode readers bidirectional? For example, if the barcode sequence is 01234567 and I swipe the card in reverse so that the numbers appear as 76543210, will they both be interpreted as the same?
Thanks!
They will read out the same. The barcode itself is duplicated in reverse halfway down the middle.
So if you swipe forward, or if you swipe reverse, the same code will be recognized.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/655509-laser-barcode-question/#findComment-8440954
Sounds great, thanks!
https://linustechtips.com/topic/655509-laser-barcode-question/#findComment-8449143
