Hello, I'm looking to upgrade my current gaming pc and I wonder how what kind of hardware I should go for and if It's worth it.
This is the pc I'm looking to upgrade and the budget is 2000USD.
2x 780ti
1TB Samsung 840EVO
i7-4770k
32GB DDR3 RAM @1600Mhz
MSI Motherboard(Can't remember the name but it's a cheap one)
I would love some suggestions on what I should upgrade :)
https://linustechtips.com/topic/655401-help-with-upgrading-a-pc/
2x 780ti
1TB Samsung 840EVO
i7-4770k
Just build a new PC with that money, it would be more worth it.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/655401-help-with-upgrading-a-pc/#findComment-8430633
Honestly, with 2k, you may want to just build a whole new system on Skylake platform. What case and PSU do you currently have?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/655401-help-with-upgrading-a-pc/#findComment-8430647
It's a 1000W Coolermaster PSU and a Coolermaster case(It's a custom OEM one so I don't know it's specific name).
Okay, do you have any suggestions for a build? :)
https://linustechtips.com/topic/655401-help-with-upgrading-a-pc/#findComment-8430713
Just now, Jojjerino said:
4k gaming on high/ultra settings and perhaps VR(according to the SteamVR test my GPUs wasn't ready..
It seems pointless to make a new build with the current generation of processors since yours isn't that far behind them. You'll want to wait for Zen and Kaby Lake if you want any actual performance gains from what you have. Same with graphics cards. Getting a 10 series to be futureproof is pretty stupid since it's just a 16nm Maxwell. Especially with AMD's Vega coming Q1 2017.
Unless you *need* immediate performance boosts (your budget would be higher than 2k if it was that urgent). Then you can just buy 2 1080's and be done with it.
https://linustechtips.com/topic/655401-help-with-upgrading-a-pc/#findComment-8430993
http://pcpartpicker.com/list/9wG78K
This is a bit rough but its a basic outline of what you can get.
Desktop
LAPTOP
https://linustechtips.com/topic/655401-help-with-upgrading-a-pc/#findComment-8431007
4 minutes ago, Maddalol said:
Upgrading to skylake is pointless for you. If you "need" to upgrade right now I would just buy 2 1080, but I would wait as @MaxBunny said.
Okay I see your point, I'll probably wait and see what future has in store for us. :)
Thanks
Thank you for taking the time to create a list I appreciate it :) but I might wait a bit for the next generation of hardware as the other posters as suggested.
https://linustechtips.com/topic/655401-help-with-upgrading-a-pc/#findComment-8431620
