Java Help Requested
Go to solution Solved by Smokeythebear,
System.out.println(inches + "inches are equivalent to " + var);
If I'm remembering this correctly.
Hey guys,
Im taking an intro class in programming in Java for a possbile future job opertunity.  Currently the project calls for this statment to be printed " 10.0 inches are equivalent to 25.4 centimeters. ". I'm having inssues formating the print line correctly.  Heres my code for more detail.
public class MetricLength
// Lab1
public static void main( String [] args )
                        double var;
   double CM_PER_INCH;
      CM_PER_INCH = 2.54;
   double NM_OF_INCH;
      NM_OF_INCH = 10;
      var = NM_OF_INCH * CM_PER_INCH;
     System.out.println( );
Thanks in advance!
"45 ACP because shooting twice is silly!"
https://linustechtips.com/topic/655295-java-help-requested/
System.out.println(NM_OF_INCH * CM_PER_INCH);
or
System.out.println(var);
Oh, and I would just format things a bit differently. It will make your life easier in the long run.
public class MetricLength(){
    public static void main(String[] args){
         double cmPerInch = 2.5;
         double inches = 10;
         double centimeters = cmPerInch * inches;
         System.out.println(centimeters);
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/655295-java-help-requested/#findComment-8422805
3 minutes ago, MaxBunny said:
Java is pretty horrible. You're going to hate your life if you pursue this path. :P
I should probably rephrase that, currently I need to get into coding and practice.  So far this is decent practice and I'm catching on fairly quick.  However Powershell is needed for my ACTUAL job opportunity.
or
Hmmm, I'll try that.  Thank you!
https://linustechtips.com/topic/655295-java-help-requested/#findComment-8423223
13 minutes ago, djdwosk97 said:
-snip-
Note taken on the formatting, thank you!  Also I need the output to be " 10.0 inches are equivalent to 25.4 centimeters. "
Currently the error I'm getting with my code is as follows:
MetricLength.java:21: error: ')' expected
     System.out.println( "10.0 inches are equivalent to"(var) );
MetricLength.java:21: error: not a statement
MetricLength.java:21: error: ';' expected
3 errors
https://linustechtips.com/topic/655295-java-help-requested/#findComment-8423779
