CPU Upgrade help
Go to solution Solved by 007agentHP,
it supports the q6600
none of the others
Hi, I have a Dell Precision 390. Right now, I am looking for a CPU upgrade for the machine. I have a Intel Core 2 Duo 6300 in there right now (1.86GHz) . A few questions,
1. Does it support the Intel Core 2 Duo E7500?
2. Does it support the Intel Core 2 Quad Q6600?
3. Does it support the Intel Core 2 Quad Q9650?
What is the fastest CPU I can put in this thing? (I do not care about price or price-to-performance)
Please read my question on the Server and NAS section.
https://linustechtips.com/topic/655198-cpu-upgrade-help/
none of the others
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/655198-cpu-upgrade-help/#findComment-8417580
1 minute ago, IBM_THINKPAD_R51 said:
@dexxterlab97THANKS!
Hey there, sorry to ruin your fun, but I'm pretty sure the stock Dell chipset of that generation doesn't support the QX/Q9650, or any Quad Core for that matter.
So you're limited to single or dual cores (maybe get an extreme core 2 duo?)
Source: Dell Product Page
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/655198-cpu-upgrade-help/#findComment-8417919
