So I was looking at getting a new GPU pretty soon and I was wondering if anyone knows a formula to estimate how much power the maximum draw a GPU requires based on the pin connection layout.  As an example, if there is a single 8-pin connection vs a single 6-pin or a 6-pin plus an 8-pin.  This is not taking into account the 75 watts drawn from the PCI-E slot. In other words, a ballpark figure or the power requirement for a card with a single 6-pin, sinlge 8-pin and an 6 and 8-pin combination. I know my PSU probably won't be able to power a card with two 8-pin connectors, but I am looking at several Radeon cards that have a 6-pin and an 8-pin.  Most retailers state a minimum PSU wattage requirement, but I know these figures are inflated to take into account other cards, devices, and peripherals of the setup.
https://linustechtips.com/topic/655014-gpu-power-pin-connectors/
GPU power draw can't be determined by the connector. Some cards can draw 90w from a 6-pin connector, while others can draw upwards of 120w from that same connector. You'll have to check the individual card manufacturer's website. (Keep in mind that XFX's implementation of a certain card will differ from Asus's implementation of that same card, so you'll have to check all the cards you're looking at). Look at the raw TDP, which is generally a good representation of the amount of power taken (not the definitive number).
"Not breaking it or making it worse is key."
"Bad choices make good stories."
https://linustechtips.com/topic/655014-gpu-power-pin-connectors/#findComment-8409512
There's no good way to estimate it based on pin connectors. For example, a 1070 has an 8 pin, which combined with the pcie connector gives 225 watts, but in reality the power draw is more like 150 watts. On the other hand, a 295x2 has two 8 pins which added with the pcie slot gives 375 watts but in reality the power draw is more like 500-550 watts. The best you can do to estimate is just look at the tdp. I know the tdp isn't the same thing as the power draw but in generally it's pretty similar. If you want something more accurate just look for reviews by people like tom's hardware who measure the exact power draw of a card.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/655014-gpu-power-pin-connectors/#findComment-8409657
At best you can only estimate the minimum power draw it has based on what connectors the video card requires. You cannot estimate how much it'll actually use. However both AMD and NVIDIA put down the power spec on their website. But this is only for the stock version of the card. Board manufacturers will often sell overclocked versions that require more power.
If you really want to know what the maximum power delivery for each connector is though:
  • PCIe slot: 75W
  • 6-pin connector: 75W
  • 8-pin connector: 150W
However this does not mean a card with a 6 and 8  pin connector will draw 300W. It may draw up to 200W. But you can guess it will chew up at least 150W (from the PCIe slot and 6-pin connector).
https://linustechtips.com/topic/655014-gpu-power-pin-connectors/#findComment-8409742
Thanks for the replies,  This is a frustrating topic for me personally due to what I pointed out in the OP that the MSR givien by manufacturers are always seriously inflated due to having to cover a whole spectrum of other devices that may possibly be in a build.
These are two excellent examples of what I was talking about.  I know that cards are often rated outside of what they actually require.  This is why I was looking for a "ballpark" formula of how to determine the maximum TDP
  • PCIe slot: 75W
This is very helpful to know, I want to be certain of what the maximum possible  TDP parameters can be to make an estimate without having to dig through articles and review specs to rule out any GPU's that I know are definitely out of my power range.
Back @DocSwag, if the maximum TDP a slot and two 8 pin connectors can provide are 375, how is it even possible for an R9 295x2 to even draw that much power which exceeds the supply the connections can provide?
https://linustechtips.com/topic/655014-gpu-power-pin-connectors/#findComment-8410433
  • PCIe slot: 75W
*Stares at RX 480*
https://linustechtips.com/topic/655014-gpu-power-pin-connectors/#findComment-8412569
First off, I want to clarify something since this is a pet peeve of mine. TDP is not power consumption. It's how much thermal energy is required for a cooler to dissipate in order for the GPU to run at the designed operating temperature given a nominal workload. Yes it's measured in watts, but in physics, anything that's energy over time, be it thermal, electrical, etc. is measured in watts. Because it's energy. And energy is all the same in the end.
Anyway.
The thing with power delivery is that the PCIe defines a maximum power delivery. However, all that means is to be compliant, you have to be able to supply up to that much safely. If your power delivery system is built with more beef, you can exceed the power delivery spec safely. This is why the RX 480 burns out some boards but not others. But again, there's no easy way to determine the maximum power a video can consume based on its connections alone.
As in my previous example, a video card that consumes 200W may use a 6-pin and 8-pin connector rather than say a single 8-pin because the headroom is 25W. Maybe you need to worry about power spikes, overclockers, etc. So you put on another 6-pin connector to give yourself another 75W of breathing room.
In any case you can only rely on two things: what the manufacturer says (NVIDIA and AMD both have typical board power consumption for the stock card listed on their website) and what reviewers say, if they do a power measurement test (Tom's Hardware is the only one I know that does an isolated test).
https://linustechtips.com/topic/655014-gpu-power-pin-connectors/#findComment-8418850
