Hi, I have never haved a pc before because i am used to laptops but all have failed me so i now would like a pc.
I want everything needed including, monitor + peripherals + pc for under 550£
Currently i have built this but i need some suggestions on how i could get it cheaper.
http://uk.pcpartpicker.com/list/kVqtnn
Please dont hesitate to tell me improvements as i am not the most experienced with pcs.
The computer would be used to run fps, shooters like csgo and overwatch. I dont mind playing on medium settings as long as it dont look too bad but i want at least constant +60fps on 1080p
I would occasionally do some school work too
Please tell me what you think, Thank you! :)
UPDATE
after some helpful build suggestions,  i changed some stuff so can someone please rate this build? thanks :)
http://uk.pcpartpicker.com/list/WznW4C  rate this build please? most of it was chosen from helpful people above but i changed some,
Edited by vbest
https://linustechtips.com/topic/654792-first-gaming-pc-build/
great to see a new builder - after all im building my pc tommorow, but i reccomend hyperthreading
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401217
http://uk.pcpartpicker.com/list/nTWFgL I would recommend an rx470 but it is to much for your budget
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401222
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  (£105.46 @ Scan.co.uk)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard  (£55.36 @ Amazon UK)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  (£25.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£42.99 @ Ebuyer)
Video Card: PowerColor Radeon RX 460 2GB Red Dragon Video Card  (£98.99 @ Ebuyer)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  (£47.30 @ Amazon UK)
Power Supply: XFX TS 430W 80+ Bronze Certified ATX Power Supply  (£36.22 @ More Computers)
Operating System: Microsoft Windows 10 Home OEM 64-bit  (£0.00)
Monitor: Asus VC239H 23.0" 60Hz Monitor  (£118.97 @ CCL Computers)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  (£29.80 @ Amazon UK)
Total: £561.08
Generated by PCPartPicker 2016-09-04 18:22 BST+0100
This is the closest I could get you to 550£ (included IPS monitor with speakers). You Don’t Need a Product Key to Install and Use Windows 10
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401225
3 minutes ago, Squarq said:
I don't believe you need to buy the Windows 10 Home Key, you should be able to make a bootable usb on another system and then install from there.I also recommend trying to find a cheaper monitor, that one's pretty pricey.
I currently use a laptop i bought from pc world, it has    Windows 10 Home 64 bit, will i be able to move windows 10 from this or no?
The monitor is 1920*1080 like i wanted, and it has a very fast response time, but ill look now for others
Thanks
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401232
Thanks
Response times below 20ms are impossible to tell apart.
Computer Specs:
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401238
Thanks
Yeah, you should just look for a video on how to create a bootable usb for a windows 10 install. All you need is a working pc or laptop with internet, at least a 4GB Usb, and some common knowledge.
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401245
Just now, vbest said:
really? does that mean its basically pointless as 90% of response times ae lower than that?
Yup. A very high response time will cause blur in moving images as pixels take time to switch color. But below 20ms (which is one fiftieth of a second) the blur is imperceptible.
Computer Specs:
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401266
Unless you plan to go major league CSGO, you shouldn't worry too much about response time as long as it's below 15 or 10ms if you're up for it
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401269
Total: £561.08
Is the RX 460 good for gaming?
Also should the processor be the same price as the graphics card?
Thanks for your builds /improvements
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401272
Thanks man, i didnt know this was possible :)
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401279
RX 460 is a capable gaming card, the R9 380 is 20% faster but also 50% more expensive. If you want a better GPU for more, the RX 470 is 80% faster for  £170
http://uk.pcpartpicker.com/product/Hz648d/sapphire-radeon-rx-470-4gb-video-card-11256-00
Computer Specs:
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8401305
Total: £561.08
Thanks for the list but i heard you should buy a good PSU as it runs your whole computer and i have never really heard of it and i havent seen many buyer reviews. Would it be better if i was to buy  http://uk.pcpartpicker.com/product/HvTmP6/evga-power-supply-100w10430kr
It has alot more reviews?
idk much so advise me please lol, thanks ;)
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8461962
7 minutes ago, thom derksen said:
Maybe you could consider the BENQ GL2250(hm)? It led backlit, has a 2ms response time and I like it myself:P
hmm https://www.amazon.co.uk/BenQ-GL2250-21-5-Inch-Monitor-Black/dp/B005LNZU2Y/ref=cm_cr_arp_d_product_top?ie=UTF8
Right now its on offer to 78£ from 110£
nevermind ignore lol
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8462295
No need for a valid product key? i thought the bootable usb is only for installing but a valid key is still needed to activate win 10?
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8462831
Yeah, I am very acquainted with Quality PSUs (I help run the new PSU Tier List) and can assure you that the XFX PSU is not only good, but quite a bit better than the EVGA one.
Computer Specs:
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8467346
Thanks !
If you can afford the 25 more pounds, an IPS display is worth it. Compared to "Standard" TN monitors, IPS ones have much better color accuracy (and a wider range of color) and viewing angles.
http://uk.pcpartpicker.com/product/Nk648d/asus-monitor-vc239h
(It still has built-in speakers)
Computer Specs:
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8467402
I will stick with the xfx psu then, thanks for the help.
Also with the monitor, is there any you would recommend which is cheaper IPS and has no built in speakers? because i would mostly use the pc with a headset.
Thanks ;)
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8494577
i just checked monitors with 1920*1080 and ips, and i think that is the best one for the price right?
Thank you :)
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8494599
Can someone tell me the actual answer please?
I got this laptop which came with windows 7/8 i think (Cant remember) and i upgraded it to windows 10 home.  Will i be able to transfer the OS from this laptop to a new computer by USB???
https://linustechtips.com/topic/654792-first-gaming-pc-build/#findComment-8494630
