Hey i am trying to build a new machine on a budget for gaming... I wanted to use an ASUS Radeon RX 460 STRIX O4G, 4096 MB GDDR5 as a gpu.but i dont now if it's performance will be worse or not at "full steam" if i use an AMD X4 860K as a CPU...I have to stay on a low budget so is this cpu good enough or if not can you give me advice on a cheap good cpu?
https://linustechtips.com/topic/653765-first-build-help/
Hi! The 860K is still a fine CPU for games that don't rely on it too much (some shooters, RPGs, racing games)
If I was you, I would save up a bit more and get an i5 6400, you can survive on the 860K until then.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/653765-first-build-help/#findComment-8392395
