Just now, Thread212 said:
If your motherboard has built in sound card then u dont need to buy it.
make sure u install the latest driver and plug the headphone at the back panel not the front,plug it in the front if u already plugged the audio front panel cable.
One of the connections was just lose, thanks a lot.
https://linustechtips.com/topic/653678-no-audio/#findComment-8391409
