i would go for an i5 6600k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117561
with this cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&cm_re=hyper_212-_-35-103-099-_-Product
and this motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130912
you probably want 16gbs of ram or so, just make sure its ddr4 and your good, can't go wrong with this setup
https://linustechtips.com/topic/653671-help-with-new-build/#findComment-8391352
14 minutes ago, clock said:
Hi
I want help with new build around 1200$
I wan it  for graphics design and gaming
Please exclud : monitor, case,  powesupply,  mouse, keyboard
I hope it will have 1070
Thanks
6700k
asus z170 pro gaming
gtx 1070
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/653671-help-with-new-build/#findComment-8391361
Just now, SeanAngelo said:
6700k
gtx 1070
6700k is a bit overkill, spend it more on gpu or something
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/653671-help-with-new-build/#findComment-8391416
