Hello everyone, I build my PC three years ago and it is time to upgrade. I want to upgrade my CPU and Graphics Card and I don't know if I have to change other parts as well, if I do so. I am thinking of buying a i7 6700K and a GeForce GTX 1060 or 1070. Can I just buy those parts and build them in or do I need to change my Motherboard as well? And if I change my Motherboard, wouldn't I need to change my Memory, too?
My current build is:
- Motherboard: ASRock Z77Pro3 Intel Z77 So. 1155 Dual Channel DDR3 ATX
- CPU: Intel Core i5 3570K 4x 3.40GHz So. 1155
- Graphics Card: EVGA GeForce GTX 780 Superclocked ACX Cooler Aktiv
- Memory: HyperX Predator DDR3-RAM Kit 16GB (2x8GB)
- Case: Sharkoon T28 Midi Tower
- Power: 530 Watt be quiet! Pure Power CM Modular 80+ Bronze
- Cooling: Z!AL-EOL CPUK Thermalright HR-02 Macho
I am also thinking about buying the NZXT S340 Case. Is this possible?
https://linustechtips.com/topic/653108-need-help-at-upgrading/
if you want to upgrade your cpu to a new i7 or i5, you will have to buy a new 1151 motherboard, and ddr4 ram for it. though, the performance difference isn't likely worth swapping all those parts, i would go with an i7 from that generation that wouldn't make a huge difference in performance compared to the new stuff, but that is up to you and what you want to do with it. however, you can buy a new graphics card without any problems, which is where you should start, then see if the performance is good enough for you.
https://linustechtips.com/topic/653108-need-help-at-upgrading/#findComment-8385904
I agree with an S340 case, it's beautiful and easy to build in (save for the drive cages.
Looking at you setup, there's a couple places I'd want to upgrade first.
Storage: Do you have an SSD? They are worth their price and then some.
Monitor: A GTX 780 is still basically fine for 1080p, and if you want you could get yourself a display upgrade alongside new graphics. 1440p display + GTX 1070 should be about $650
For an i7-6700K you would need a new motherboard and memory.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/653108-need-help-at-upgrading/#findComment-8385912
6700k is LGA1151.
new MB in your future.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/653108-need-help-at-upgrading/#findComment-8385913
Somebody feel free to correct me if I am wrong, but I dont believe your current CPU and the i7 6700K use the same socket type which would mean you would need to get a motherboard that is compatible with the 6700K.
Edit: Took to long to post question has been answered lol
https://linustechtips.com/topic/653108-need-help-at-upgrading/#findComment-8385918
No, I don't have a SSD but I want to buy one. What size or brand do you recommend?
My Monitor is the BenQ XL2420T 24" with 2ms. I think it is a 1440p display.
https://linustechtips.com/topic/653108-need-help-at-upgrading/#findComment-8386067
Looks like your monitor is a 1080p 120Hz display. I'd say that's pretty good, depending on what games you like to play. The additional refresh rate (Hz) helps with racing games and shooters especially.
I recommend 240-256GB SSDS and good models are:
SanDisk Ultra II
Crucial MX200
Samsung 850 EVO
SK Hynix SL308
See which one is cheapest of these, and go for it :)
Computer Specs:
https://linustechtips.com/topic/653108-need-help-at-upgrading/#findComment-8386100
On the topic of CPU: if you want to upgrade it, I would choose i5-6600K, keep the cooler, and overclock it on a Z170 motherboard. Also get some fast DDR4 RAM.
Computer Specs:
https://linustechtips.com/topic/653108-need-help-at-upgrading/#findComment-8386107
