NVIDIA 331.40 Driver Problem
Go to solution Solved by miyabwah,
Okay, so I updated via Device Manager, but I'm not sure if it really "worked".
EDIT - Wait, okay it worked. I guess I'll just update via Device Manager from now on.
Strange. Does it occur with other driver revisions as well?
Could you try doing it again using the Installer?(But don't actually install them)
