Installation Order.
Solved by Electronics Wizardy,
Just now, Gazeley said:@Electronics Wizardy So basically get windows installed, install wifi adapter using cd and then the drivers for the gpu can be found online?
1. Install windows
2. Check for wifi, if you see your network, no need to install wifi drivers, there already there.
3. Once you have internet, let it sit overnight or for a hour or two. You should amd stuff if you right click on the desktop. If a you can't use part of the hardware(like a raid card or audio) then install drivers, but you should be just fine.
With windows 10 you can normally get away without installing any drivers as there installed from windows update. Its gotten much better than windows 7.
