3 minutes ago, aries757 said:
yes but my budget is very strict of under 550
Well it's like .41 over but this maybe? http://pcpartpicker.com/list/jjwFgL
or you can ditch the ssd for a smaller one...
I am a paid professional, but only when I am at work...and getting paid.
https://linustechtips.com/topic/652499-best-550-dollar-pc-build/#findComment-8380200
Add a 1070 to the t3500 + w3550 off my post and you should be able to run anything at 2k fine(I've inly tested with a 970 but have had zero issues except in the most cpu intensive games, overwatch,starcraft 2, starwars battlefront,rust and fallout 4 have run fine on it with max settings(no AA @ 1080p)
https://linustechtips.com/topic/652499-best-550-dollar-pc-build/#findComment-8388713
