Hi, I have a computer with windows 8 installed on it and it was working perfectly fine untill one day when I turned on my PC it booted up to the login screen but the screen started flickering and eventually just turned into a black screen with only my mouse pointer visible. I have tried CTR ALT DEL but nothing comes up. I even reinstalled windows but was faced with the same problem. I ran a check disk command and it said that my hard disk was corrupted could this be the issue? I have tried to boot into safe mode and that works but what do i do now?
https://linustechtips.com/topic/652339-startup-problem-black-screen/
I would back up any files that you need. Once that's done, take the HDD/SSD and SATA cable and attach it to another computer. Open command prompt (Win + R > "cmd"). Once the window opens type "diskpart". Say yes to the pop-up.
"List disk"
Find the disk you just attached.
"Select disk X" X = the drive # you need
"clean all" and wait for it to finish.
This will break any MBR/MFT on the drive and write zeroes on every single bit on the drive.
After that, return the drive to the rightful owner and reinstall Windows.
Let me know if you need more help by quoting and deleting whatever is in the quote box with a -snip-.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
8 minutes ago, hassan098123 said:
Can this not be done on my own PC?
No, you're breaking the OS (by zeroing the drive rather than formatting) for a fresh install.
"List disk"
Hey I tried what u said but it still didnt work should I replace my Hard drive? The screen flickers and then goes completely black but that doesnt happen in safe mode so im adsuming its not a GPU problem
No. If it doesn't happen in safe mode, I would start by checking every driver you have.
Before that, can you do "chkdsk [drive letter]:" from cmd.
