Hey all, I have a Asus P5N-SLI motherboard and I am trying to flash a new bios to it. I was desperately trying to put windows 10 on the computer, after giving up I tried to put in windows 7. The computer got the the "STARTING WINDOWS" screen then blue screened. I looked this up online and people were saying that this was easily fixed by a bios update. Seeing as I still had the original bios on my computer that seemed reasonable. I got a 1gb flash drive formatted to FAT as others suggested. I clicked select on the update i wanted in the EZ flash 2 program and it gave me this message "downgraded ROM file was not suitable for the system". I tried all the other updates on the site and tried to see if it would work in FAT32, I even tried a CD rom.   Please help.
Headphones:
Sony MDR V6 (DT 250 pads), restored 1987 AKG K240M 600ohm (Cosmos pads with dt250 filters), AKG K7XX, Beyerdynamic DT990 pro 250 ohm, Bose Ae2 & Sony MDR v150. All off of a Bravo V2 shuguang tube, Little Dot mkII with GE JAN 5654 tubes, a CEntrance Dacport slim and a UCA222.
PC:
  • CPU
    i7 6700k
  • Motherboard
    Asus Z170s
  • RAM
    Crucial Ballistix (white)
  • GPU
    Asus 1070 Strix OC
  • Case
    Phanteks P400
  • Storage
    Samsung 850 pro, Seagate barracuda 1tb
  • PSU
    Evga G1 650W (regret)
  • Display(s)
    Samsung S22D300 21.5" 1920x1080 60hz 5ms & ASUS PB277Q 27" 2560x1440 75Hz 1ms
  • Cooling
    Deepcool Captain 240EX white
  • Keyboard
    Logitech G810
  • Mouse
    Logitech G502
  • Operating System
    Windows 10 (switching to linux soon)
https://linustechtips.com/topic/652209-bios-flashing-help/
bump
Headphones:
PC:
  • CPU
    i7 6700k
  • Motherboard
    Asus Z170s
  • RAM
  • GPU
    Asus 1070 Strix OC
  • Case
    Phanteks P400
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G810
  • Mouse
    Logitech G502
  • Operating System
https://linustechtips.com/topic/652209-bios-flashing-help/#findComment-8390784
58 minutes ago, Tsx said:
Wrong Revision. Check directly the Mainboard which Version it hast.  Rev 1.0 or 2.1 whatever. Do a picture of your Mainboard or give the Fall Name so we could Check which BIOS you need
It's the P5NSLI rev. 2.00G
Sorry for the bad cable management. It's a top mount non modular PSU with a case that has no cable management areas. I'll fix it up later.
Headphones:
PC:
  • CPU
    i7 6700k
  • Motherboard
    Asus Z170s
  • RAM
  • GPU
    Asus 1070 Strix OC
  • Case
    Phanteks P400
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G810
  • Mouse
    Logitech G502
  • Operating System
https://linustechtips.com/topic/652209-bios-flashing-help/#findComment-8391250
https://www.asus.com/Motherboards/P5NSLI/HelpDesk_Download/
  1. Select your os
  2. Open drop down for bios
  3. Download the first entry
  4. Unzip so you have the bin file
  5. Upload it to an usb stick which is fat32 formatted
  6. http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5N73-AM/QG4204-PC-AID_II.zip?_ga=1.175151396.763419637.1472208085
  7. Step 6 is your mainboard manual
  8. Step by step there is an introduction how to flash now.
https://linustechtips.com/topic/652209-bios-flashing-help/#findComment-8429721
