first build pc
Solved by Blind X,
2 minutes ago, defrid said:Okay thanks for the information you suggested for me
ao i've been looking msi h170a gaming pro and asus h170 pro usb 3.1 which one is the great deal? Asus is much cheaper tho
MSI H170A Gaming Pro is top of the line H170 series motherboard. Its upto you. They are really very close to call.
