Going 1440p Upgrade?????
4 members have voted
  1. 1. Upgrade 2016
    • keep 980 lower settings
    • Sell 980 buy used 980ti
    • Sli 980
    • Sell 980 then save for 1070
https://linustechtips.com/topic/651580-gpu-help/
Keep 980, Lower Settings.... Because after Xmas..... Directly after.... there will be more USED cards on the market to choose from.
Xmas has more people selling used GPU's when they get their shiny new ones for Xmas.
Deal with 1440p @ Mixed Medium-Ultra settings for a little bit, and then find a bargain when the influx of USED cards come to market after Xmas.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/651580-gpu-help/#findComment-8371348
First of all you can keep the 980. See what framerates it is capable of. I was supprised what my 970 was able to do at 1440p. Then maybe look for a used 980Ti or a 1070 if the performance isn´t what you expected.
CPU: AMD Ryzen 9 5950X PBO GPU: Asus Strix RTX 3090 OC Mobo: Gigabyte X570 Aorus Master RAM: 32GB G.Skill Trident Z RGB 3600Mhz CL17
CPU Cooler: Corsair H150i Capillex Storage: Samsung 980 Pro and 970 Evo 1TB Samsung 860 EVO 1TB Crucial MX300 525GB WD Black 2TB PSU: Corsair HX1000 Case: Corsair 500D SE RGB 6x LL120
https://linustechtips.com/topic/651580-gpu-help/#findComment-8371419
