 I am making a PC for the first time and have run into a problem, which gpu do I buy??? I plan to use this rig for 4K gaming and video streaming. My budget is $1500-2000 including peripherals. My rig so far is:
NZXT h440-free
WD back 1TB-$80
Asus rog maximus vllll-free
Intel core i7 6700k-$320
32gb of ddr4 corsair vengeance led ram-$182
Intel 750 series ssd-$363
Nzxt kracken CPU cooler-$115
Total:    $1060
So what gpu should I use for 4K gaming and video streaming.
https://linustechtips.com/topic/651193-help/
If you have $1,500-$2,000 for everything, ( What other Peripherals? Keyboard? Moue? )
There really isn't anything stopping you from getting a Titan XP with that budget, assuming you can find one at the MSRP.
Though, have yet to look into high end GPU's, I'd look into seeing what high end AIO GTX 1080 like the Hybrid, MSI SEA HARK, or Gigabyte XTREME whatever cooling performs at when overclocked very high and see if the FPS difference is worth it over having possibly 2-3 monitors and ( don't quite know ) keyboard/mouse ect.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/651193-help/#findComment-8366940
NZXT h440-free
WD back 1TB-$80
Total:    $1060
with 8gb is enough for gaming, up to 16gb, 32gb of ram is a waste of money for gaming, for 4k gaming gtx 1080 for sure
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/651193-help/#findComment-8366951
NZXT h440-free
WD back 1TB-$80
Total:    $1060
https://linustechtips.com/topic/651193-help/#findComment-8366953
GTX 1080 is the best. Get an aftermarket card and overclock it a ton.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/651193-help/#findComment-8366970
