So i i.m stuck between AMD Athlon x4 860k and the Pentium G4400
În games like Arma 3 GTA V and some other games that are similar to these ones which Will perform better overclocked and non overclocked?
A side question.if i.d want to do overclocked on any of these two cpus the Id Cooling SE-902x cooler Will Be enough to keep things cool?
https://linustechtips.com/topic/650190-cpu-advice/
13 minutes ago, Cracklingice said:
I'd recommend skylake with the intention of upgrading to an i5 - or stretch the budget to get an i3 as that will be meh ok and make the x4 look like a single core.
Hmm i wont Be upgrading my pc anytime soon maybe în 2021-2022
And when i.ll do that i Will build another pc
I.d like to Be able to spend a Little more to get an i3 but i can.t
https://linustechtips.com/topic/650190-cpu-advice/#findComment-8357428
