So... im having a bit of trouble deciding on a case that i like........ yeah.
this is the current parts list i have:
PCPartPicker part list: http://pcpartpicker.com/list/CK98r7
Price breakdown by merchant: http://pcpartpicker.com/list/CK98r7/by_merchant/
CPU: Intel Xeon E5-2670 V3 2.3GHz 12-Core OEM/Tray Processor  ($200.00) (es off ebay. idc about rules, bite me)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  (Purchased For $0.00) (temporary, and i have this)
Thermal Compound: ARCTIC MX4 4g Thermal Paste  ($7.38 @ Newegg)
Motherboard: ASRock X99 Taichi ATX LGA2011-3 Motherboard  ($221.98 @ Newegg)
Storage: Samsung 950 PRO 256GB M.2-2280 Solid State Drive  ($187.93 @ Newegg)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($93.49 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (Purchased For $0.00) (already own, permanent)
Keyboard: Corsair K65 LUX RGB Wired Gaming Keyboard  ($109.99 @ Best Buy)
Headphones: Kingston HyperX Cloud II 7.1 Channel  Headset  ($99.99 @ Best Buy)
Other: Asus RX 480 Strix ($300.00)
Other: G.Skill Trident Z 3200 MHZ 32GB (4x8GB) Black/White ($179.99)
Other: AOC I2777FQ ($199.99)
Total: $1600.74
Generated by PCPartPicker 2016-08-27 18:48 EDT-0400
I really want a case that is >$200 usd, and there are so many options. the main two requirements i have is that it has watercooling support for 360mm radiators, and it has a side panel window.
currently i have a define s, and it is a really plain looking case (not to mention the side panel window is of awful quality. rainbows everywhere!)
im not opposed to having plain looking cases, but i just dont like this case for some reason...
currently i am getting really interested in tempered glass side panels, but it isnt a requirement to have, i just think they look amazing. (like on the lian li pc09)
the case i was going to get, but decided to not go for was the AI-Crystal, but they ripped the design off of rosewill (cullinan) or vice versa.... and since i am not getting this case NOW, i dont know if it will be around for 6 months!
my color scheme is black with white accents. i will be painting the gpu to have white accents and a white backplate as well, so please pick something that matches!
https://linustechtips.com/topic/650188-deciding-on-a-case-fun/
https://linustechtips.com/topic/650188-deciding-on-a-case-fun/#findComment-8360521
6 hours ago, ItsTheDEMON1997 said:
yeah... i was thinking about getting that... only thing that kinda had me worried was the back panel was TG as well.. and if i wanted it to be aluminum i would have to buy, paint, and mod that aluminum to fit.
that being said, i wont be seeing the back too often so ill probably go with this case... i originally didnt have a budget that large until now so i was straying away from that case since it seems overpriced.
https://linustechtips.com/topic/650188-deciding-on-a-case-fun/#findComment-8362596
yeah.. im not really liking the idea of tempered glass on the back, ill go with the regular model. if i feel like i want glass in the future ill mod it, otherwise the case has so many features that i like.
https://linustechtips.com/topic/650188-deciding-on-a-case-fun/#findComment-8362870
Even if you don't end up using the case for your primary build. there is like a 20 dollar mod you can do to swap the crappy side panel window for a glass one...
Costs like 30 dollars max and takes less than an hour of work. Best mod I've ever done in my life.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/650188-deciding-on-a-case-fun/#findComment-8364377
