I've been trying to get a faster oc on my cpu for some time now and I'm still not getting what I want to actually achieve any help would be much appreciated
maximus v extreme
i7 3770k
32gb ram
two GTX 680 sli
1500 watt psu
highest OC iv got is 4.2 but I must be doing something wrong because I've seen ppl achieve 4.7 if someone could give me a tutorial or how to id really appreciate the help
thanks
          Maxxspeed
https://linustechtips.com/topic/649916-oc-help/
maximus v extreme
i7 3770k
32gb ram
two GTX 680 sli
1500 watt psu
thanks
          Maxxspeed
from your processor, i7-3770k at 3.4GHz, and a up to 4.2 is a big difference as is. you might have seen people with a higher base clocked cpu like for example me with an i7-4790k at base 4.0, and OC at 4.8 currently. You could be at the limit of your OC before it becomes unstable. I havnt really messed around much in OC my cpu much more even though im on liquid cooling. some people even use liquid nitrogen to get even crazier temps and speeds on their computers. So everything takes in effect here.
https://linustechtips.com/topic/649916-oc-help/#findComment-8354824
Just because other people have gotten 4.7 doesn't mean you or anyone else will. In part due to the silicon lottery.
When you are going to overclock the first thing to do it is set everything to stock values. This means going into the BIOS and turning it from auto to a set value.
Then you increase the multiplier of the CPU and test if it is stable with a stress test if it is then you can increase the multiple again. When it becomes unstable you increase the Vcore.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/649916-oc-help/#findComment-8354846
