I need some help guy
Go to solution Solved by 007agentHP,
well here is a very useful site ill link you
https://pcpartpicker.com/list/
it allows you to put in your parts and it will only allow you to select parts that are compatible with other parts, so you dont make any mistakes
Hello everyone I need some help!
I'm about to start building a custom pc and the type of cpu im going with is the " Intel® Core™ i7-6700 " I was wondering if anyone would know the best asus motherboard out there for this type of processor! if you guys can help me out that would be amazing!
:):D:o
Thank youI
https://linustechtips.com/topic/649683-i-need-some-help-guy/
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/649683-i-need-some-help-guy/#findComment-8352988
5 minutes ago, coolmenxlz1 said:
What do you think about the "ASUS TUF SABERTOOTH Z170 S" ??
Don't bother with a Z170 motherboard unless you have a K CPU (This indicates if its unlocked or not), you need both a K CPU and Z170 to overclock and to have one without the other is a waste of money. Just get a H170 or B150 motherboard and stick with the stock cooler unless you plan to overclock. Also quote us when you reply so we get a notification and can reply easily.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/649683-i-need-some-help-guy/#findComment-8353026
ok, but i looked online and the h170 cost around $130 and z170 only cost $150 with that board i get more PCI express slots and usb slots.
https://linustechtips.com/topic/649683-i-need-some-help-guy/#findComment-8353233
