so i have the fractal core 1000 and will be adding a graphics card (as pictured) that has 2 fans and i am worried about the card getting starved, since the front 120mm runs on 5v and does not provide a lot of air i was gonna add a slim 120mm fan and i would like some good suggestions,
thanks
post-25740-0-53323400-1381610378_thumb.j
Main: AMD Athlon X4 750K| Coolermaster Hyper TX3 EVO | Gigabyte GA-F2A75M-HD2 | 8GB Kingston 1333mhz | WD Caviar Green 1tb | Coolermaster N200 | OCZ coreXstream 500w | Sapphire Radeon HD 7850 2GB | |Kingston 3k ssd 128gb |
https://linustechtips.com/topic/64920-airflow-in-my-case/
I would like to help but i'm not the best at airflow stuff:
I just add more fans.
- teamspeak.ltt-unofficial.com
- teamspeak.ltt-unofficial.net
- teamschnitzel.ltt-unofficial.com
- teamschnitzel.ltt-unofficial.net
cpu: Intel sandybridge-E 3930k @ 4.2Ghz
cooler: corsair h100 @ full speed push-pull
motherboard: Asus Rampage IV Extreme
gpu: 2x EVGA GTX660's & 1x EVGA GTX980
ssd: 2x samsung 256GB 840 pro raid 0
ssd: 1x samsung 1TB 840 evo
hdd: WD green 3TB
hdd: Seagate Barracuda 1TB (st1000dm003)
hdd: Seagate Barracuda 1TB (st31000520as)
psu: corsair ax1200i
ram: 8x 4GB corsair platinum @1866mhz
case: coolermaster cosmos II
age: Do the math (summer 2012)
monitors Main: 8x LG 22EA53 1080p 60hz
monitor Extra: 1xiiyama prolite G2773Hs 1080p 120hz 27"
os: windows 7 pro (64-bit)
keyboard: logitech g19
mouse: corsair m60
Lenovo T550
RaspBerry pi webserver:
Status: Offline.
Nas:
StatusOffline.
PC straight to the modem/router/switch/DHCP-Server/... with a 20cm (+-8inch) cat6a patch cable because same price as cat5.
ISP: Telenet (belgium)
Speed: 60Down-4Up (+- 45€/month)
ping to there servers: +-8ms
ping to other Belgians: +-12ms
- wheels for cosmos II
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-887876
learn my how to photoshop, you're the photoshop master!
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-887899
What in gods name did you do???
just stacked some fan on each other.
hdd: WD green 3TB
mouse: corsair m60
Lenovo T550
Status: Offline.
Nas:
StatusOffline.
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-887910
Get a 120mm fan and have it intaking air on the side panel, which will bring fresh air to your gpu. You can stick a 92mm fan on the rear exhaust below the psu if you want more flow.
Corsair 250d - - Delidded i7 4770k @ 4.4GHz (1.15v) - - Asus Maximus VI Impact - - Corsair h100i
Asus DirectCU II OC GTX780 - - NZXT x41 & G10 w/ Push/Pull Noctua IndustrialPPC's - - Corsair ax760i
16GB Corsair Vengeance 2133Mhz  - - Samsung 840 pro (boot) - - Samsung Evo (gaming) - - WD green HDD (data)
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-887931
You monster... haha.
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-887933
;) the things you can do with MS Word lol
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-887940
Any good ideas for quiet case fans?
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-887943
Undervolted Cougar Turbines are a good choice. I got the 4 pack one for around $20 CAD and it was a great deal imo.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-887993
cant get them in the uk.. damm
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-888006
in a positive or negative way?
hdd: WD green 3TB
mouse: corsair m60
Lenovo T550
Status: Offline.
Nas:
StatusOffline.
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-888313
Definitively positive. MOAR FANS
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-888459
Thanks this helped alot.
https://linustechtips.com/topic/64920-airflow-in-my-case/#findComment-888492
