CPU cooler <120mm
I plan on getting the Corsair Air 240, which states that the max height accepted is 120mm for the heatsink/fan. I have read somewhere that you can go up to 125mm... but I'm sure that is taking away from a gap that is probably best to keep...
My go-to cooler has been the CoolerMaster Hyper 212 Evo.. but that is just way to big.
This will be for a Xeon 1231 v3, so it won't produce an insane amount of heat.. buy I wanted to go aftermarket to keep it a little cooler.. and a not as loud since the case is pretty open.
Any recommendations?
Thanks!
https://linustechtips.com/topic/648867-cpu-cooler/
Where are you shopping/located?
https://linustechtips.com/topic/648867-cpu-cooler/#findComment-8353679
Thank you for the replies! After looking into the air 240, I must have been blind to it at first... But it doesn't include any 5.25 bays.. And call me old fashion, I just like my drive bays! Besides.. how else am I going to rip all of my dvd / blurays!
I ended up getting the air 540, love the case.. so I went with my status quo 212 evo.. (My xeon 1231 v3 tops out around 48c , and my gtx 970 is only hitting 73 rarely..
Just need to find something to control all of these fans now ( I added 2 extra ), may throttle them down a little..
https://linustechtips.com/topic/648867-cpu-cooler/#findComment-8359094
