Installation help (should be easy)
Solved by Ryujin2003,
1 minute ago, Kurt101 said:thankyou, i am dual booting as i am testing windows 8.1, i hate windows 10 as of now as its keeps forcing me drivers, which are corrupting the currently installed ones and is just basically causing mayhem, so i am seeing where ether i should just buy windows 8.1 as i have control over it.
If you just want to test, and not worry about drivers, get Virtual Box. It is much easier in my opinion (for whatever thats worth). Good luck.
