Hi,
I need some advice on setting up a p/p config with the Alphacool Monsta. I'm planning on installing TT Riing 12 fans for pushing and some other (possibly Corsair ML120) for pulling. The problem is with keeping the airflow consistent. As I understand, both need to be set to the same CFM, and CFM scales linearly with RPM. Is this (approximately) true? Can I simply assume linear relation and tune the pull RPM to match the push CFM and the air will flow fine without stressing the fans?
https://linustechtips.com/topic/648804-pushpull-with-different-fans/
i would only use the same fans running from the same splitter for a push pull config if i was doing watercooling, its hard to match the exact same CFM with mismatched fans
Builds:
