Hi all, I just finished downloading Fallout 4 onto my PC and after I click Play in the launcher the game loads up to a black screen, and then exits completely. No intro movie plays, no sounds, nothing.
Useful information:
1680x1050 screen resolution
Intel i5 6600 CPU
8.0GBs of RAM
No dedicated GPU, just using the onboard's
ASUS B150M Plus D3 Motherboard
Running Windows 10 Anniversary update.
Running it in a window does nothing to alleviate the issue, nor does Compatibility mode or running fallout4.exe as an administrator helps.
I've restarted my PC after installing it. No change.
Lowering the resolution down does nothing either.
Any ideas? I'd hate to have wasted 24.1GB of ISP download on a game that won't run.
https://linustechtips.com/topic/648448-fallout-4-will-not-load-please-help/
