Hi guys,
New to this forum but have been watching Linus Tech Tips on the tube for a while.
Planning on building an i3 / gtx 1060 gaming 'console' (ie, living room computer) that I want as quiet as possible. I'm planning on using a quiet case such as the fractal design r5 and a be quiet dark rock pro 3 cpu cooler but I'm wondering what my options are as far as quiet PSU's that won't break the budget. The be quiet ones seem a bit expensive. I really only need the computer quiet / silent when at relatively low loads such as when watching a movie but can handle a bit of noise whilst gaming I suppose.
https://linustechtips.com/topic/648203-quiet-power-supply/
What sort of budget are we talking about? The most quiet ones would be something such as the Seasonic Platinum Fanless series.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8337954
27 minutes ago, Gommly said:
Yeah those are even more expensive then the ones I was looking at from be quiet. Probably, looking at maybe $100 AUD (ie. $70 USD) but looking at point no. 2 in your tag am maybe thinking this is 'cheaping out'! lol
EVGA GS has a eco mode where the fan won't turn on until a certain load is put on it.
550w is all you need
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8338055
The Cheapest PSU with a fanless mode I know of is the Corsair SF450W, it uses the SFX form factor though and costs $125.
You can buy a SFX to ATX adaptor but that is another $12
PSU: https://www.pccasegear.com/products/35146/
Adaptor: https://www.pccasegear.com/products/36272/corsair-sfx-to-atx-psu-adapter-bracket
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8338058
There are some decent power supplies in that price range such as the Antec High Current Gamer 520W or the True Power Classic 550W, although I wouldn't classify them as the 'quietest'.
I'm just curious on why you're planning on having a $100 CPU cooler for a locked i3.
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8338061
I have a 550W GS and the fan comes on way too quickly. Would recommend a G2 if silence is more important, as well as the RMi.
High Current Gamer is pretty loud, not sure about the TP Classic. Also where does he mention a CPU cooler? I might just be blind.
4 hours ago, Gommly said:
Hi guys,
Assuming the masses are right here in that you're looking for a CPU cooler I would get a Cooler Master Hyper T4 and put a Noctua F12 on it. I do that myself but with a P12.
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8338866
I only hear the 212 Evo in my PC. The loudest thing is the hard drive...
My GS fan never comes on, even with an OC'd CPU and a R9 290 ( Well, it might come on but not loud enough for me to hear it ) Guess having the 850w one would make sense.
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8339150
I think the 850W has a similar fan curve but mine comes on with just an i3 4360 in the system sucking power and no GPU :/
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8339186
I was planning on an i5 6600k but decided I'd rather spend the money on the gtx 1060 but I may still upgrade in the future. The other probably main reason is I wanted premium 'quiet' parts in this build. If there are cpu coolers that are just as quiet at a cheaper price I'd be willing to listen. As it is I think I need to increase the budget on my psu.
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8340357
I'd expect the Truepower Classic to reflect the noise levels of the Seasonic G-series, since it's based on the same platform. It'd be far from being the quietest thing in the world.
You could probably do just as well with the beQuiet! PURE ROCK for $50 bucks less. If I were you, I'd be thinking about a quad core i5 6500 instead of a premium power supply.
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8341119
Be Quiet! Dark Power Pro 11
/thread :P
\\ QUIET AUDIO WORKSTATION //
5960X 3.7GHz @ 0.983V / ASUS X99-A USB3.1
32 GB G.Skill Ripjaws 4 & 2667MHz @ 1.2V
AMD R9 Fury X
256GB SM961 + 1TB Samsung 850 Evo
Cooler Master Silencio 652S (soon Calyos NSG S0 ^^)
Noctua NH-D15 / 3x NF-S12A
Seasonic PRIME Titanium 750W
Logitech G810 Orion Spectrum / Logitech G900
2x Samsung S24E650BW 16:10  / Adam A7X / Fractal Axe Fx 2 Mark I
Windows 7 Ultimate
4K GAMING/EMULATION RIG
Xeon X5670 4.2Ghz (200BCLK) @ ~1.38V / Asus P6X58D Premium
12GB Corsair Vengeance 1600Mhz
Gainward GTX 1080 Golden Sample
Intel 535 Series 240 GB + San Disk SSD Plus 512GB
Corsair Crystal 570X
Noctua NH-S12
Be Quiet Dark Rock 11 650W
Logitech K830
Xbox One Wireless Controller
Logitech Z623 Speakers/Subwoofer
Windows 10 Pro
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8341813
Actually under less than about 200W load or so (can't remember the exact fan curve but it's retarded in that unit) the fan is completely inaudible. I'll never forget the time I built a system for a client that had an i5 4460 with the stock cooler, a Gigabyte GTX 960 (to date has my favorite cooler of any GPU) and a Seasonic 550W G-series, and you literally could not hear the system when it was running both Furmark and AIDA64. If you brought your ear into fan slicing your lobe off distance, you could hear the faintest of noise from the fan in the Seasonic but everything was by-and-large audible. However, if we paired it with a GTX 970 I know the PSU would then make a shitton more noise xD
/thread :P
Except this thread is uh kinda big oops
https://linustechtips.com/topic/648203-quiet-power-supply/#findComment-8341925
