2 minutes ago, PCGuy_5960 said:
Go into the boot menu while booting...
I reset and mashed F8
safe made sounds safe?
CPU — AMD Ryzen 7800X3D
GPU — AMD RX 7900 XTX - XFX Speedster Merc 310 Black Edition - 24GB GDDR6
Monitor — Acer Predator XB271HU - 2560x1440 165Hz IPS 4ms
CPU Cooler — Noctua NH-D15
Motherboard — Gigabyte B650 GAMING X AX V2
Memory — 32GB G.Skill Flare X5 - 6000mHz CL32
Storage — WD Black - 2TB HDD
        — Seagate SkyHawk - 2TB HDD
        — Samsung 850 EVO - 250GB SSD
        — WD Blue - 500GB M.2 SSD
        — Samsung 990 PRO w/HS - 4TB M.2 SSD
Case — Fractal Design Define R6 TG
PSU — EVGA SuperNOVA G3 - 850W 80+ Gold
Case Fans — 2(120mm) Noctua NF-F12 PWM - exhaust
          — 3(140mm) Noctua NF-A14 PWM - intake
Keyboard — Max Keyboard TKL Blackbird - Cherry MX blue switches - Red Backlighting
Mouse — Logitech G PRO X
Headphones — Sennheiser HD600
Extras — Glorious PC Gaming Race - Mouse Wrist Rest
       — Glorious PC Gaming Race - XXL Extended Mouse Pad - 36" x 18"
       — Max Keyboard Flacon-20 keypad - Cherry MX blue switches
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335067
1 minute ago, r3d3mpt10n said:
Regarding the LED strips, I chose to run mine along the top and right instead of bottom and LEFT, that way I don't see the strips themselves
I think I will do that. They have magenta so it should be easier. Probably looks a lot cooler too
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335083
3 minutes ago, DutchTexan said:
They are 'RGB' $15 Phanteks 1 meter
Sweet :D
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335086
I think I am getting somewhere
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335090
@DutchTexan yey!
                    PSU Tier List: https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
CPU Celeron n2830 - GPU Integrated - RAM 1x4GB DDR3 1333MHz - Storage 750 GB 5400RPM HDD
                                                Operating System Windows 10 Home
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335097
Just now, WAR Corporation said:
@DutchTexan yey!
Ran into a brick wall...
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335102
4 minutes ago, PCGuy_5960 said:
Sweet :D
I don't think they are really rgb, but it may be my case having preselected values
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335112
RGB doesn't always mean 16.8million colors, it can be Red,Green,Blue and combinations...
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335127
@DutchTexan Try to install it on a 2.0 usb port. Sometimes usb 3.0 ports give problems, hope this helps...
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335128
So do I have to remake a bootable drive or? How would I go find a missing driving without having installed Windows? I have the cd, but no optical drive in this rig.
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335139
there is a button on thje case next to the reset button that (under the lip) that cycles betwen colours. It will change the colour of the LEDs at the base of the front, as well as the one in the power button. It should also change the LEDs
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335141
Trying that now.
it was unsuccessful:/
the issue must be the bootable drive I made incorrectly?
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335156
I have that the 6700K/6600K are compatible only with Windows 10 :S Do you think this might be the case?
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335159
@DutchTexan Maybe...
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335167
I think I will just order an external optical drive and then instal the cd key I own. The cd has to have the proper, not up to date, but proper drivers required?
after I get Windows I will plug in my wireless adapter and update all the drivers for all the hardware.
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335172
Ah that is unfortunate. Windows 10 is awful...
Glad to know that though
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335180
@DutchTexan Yeah, that actually should help :)
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335185
Try remaking the boot drive... And maybe hook up an optical drive to install Windows and then remove it...
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335190
I will purchase an external optical drive and reatempt Windows 7 professional via CD. Then if that doesn't work, then I will just have to purchase Windows 10, unfortunately.
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335215
Can I link forums here? It's because I found a forum on steam that says that the i7 6700k isn't supported with Windows 7, @r3d3mpt10n You're right
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335221
Yes you can...
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335226
Thanks for all the help guys! This is where today's progress ends. The build has been a lot of fun. Putting a computer together isn't as hard as I thought. It's a lot easier with y'all as a great resource. You will hear from me again!
Thank you so much for the help, I really appreciate it.
https://linustechtips.com/topic/647905-first-build-help/page/3/#findComment-8335227
