So I assembled my first PC. I have 2 issues atm. My MSI z170a m5 motherboard is displaying an error code of a green 0 0. It won't boot and show anything.
Secondly, my leds don't turn on. I couldn't find the led + or - connections in my Phanteks p400 case? There should be some?
CPU — AMD Ryzen 7800X3D
GPU — AMD RX 7900 XTX - XFX Speedster Merc 310 Black Edition - 24GB GDDR6
Monitor — Acer Predator XB271HU - 2560x1440 165Hz IPS 4ms
CPU Cooler — Noctua NH-D15
Motherboard — Gigabyte B650 GAMING X AX V2
Memory — 32GB G.Skill Flare X5 - 6000mHz CL32
Storage — WD Black - 2TB HDD
        — Seagate SkyHawk - 2TB HDD
        — Samsung 850 EVO - 250GB SSD
        — WD Blue - 500GB M.2 SSD
        — Samsung 990 PRO w/HS - 4TB M.2 SSD
Case — Fractal Design Define R6 TG
PSU — EVGA SuperNOVA G3 - 850W 80+ Gold
Case Fans — 2(120mm) Noctua NF-F12 PWM - exhaust
          — 3(140mm) Noctua NF-A14 PWM - intake
Keyboard — Max Keyboard TKL Blackbird - Cherry MX blue switches - Red Backlighting
Mouse — Logitech G PRO X
Headphones — Sennheiser HD600
Extras — Glorious PC Gaming Race - Mouse Wrist Rest
       — Glorious PC Gaming Race - XXL Extended Mouse Pad - 36" x 18"
       — Max Keyboard Flacon-20 keypad - Cherry MX blue switches
https://linustechtips.com/topic/647905-first-build-help/
I have a 250gb 850 evo ssd in the back plugged in. I have everything but the graphics card and an ssd. It it connected to a tv via hdmi. The case fans and cpu fan are spinning.
I am am not sure if the USB ports in the front or back as I plugged my keyboard in and could not turn on the keyboard lighting. I will get a closer picture of the board and all the connections.
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334729
1 minute ago, r3d3mpt10n said:
Have you plugged your 8 PIN CPU power cable in?
Yes
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334737
2 minutes ago, r3d3mpt10n said:
There are leads for the HDD acticity LED yes, and the LED itself is a tiny LED above the power button
3 minutes ago, InsertName said:
There should be LED connectors for the case LEDs, they are 2 small 1 pin connectors, marked LED + or something like that, or are you talking about those other LED strips?
The led strip is connected to a y connector already on the case. None of the case leds are illuminated. Only the motherboard is illuminating.
what does green 0 0 mean? The motherboard does not specify
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334745
Additionally the PC is having trouble turning off. I press the power button and it turns on easily, however shutting down seems like the power button is unresponsive
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334753
I'm sure non of the LEDs work because those single 1 pins are not connected. I couldn't find them in the pressures case wires. I feel stupid because I have been looking for those 2 single connectors for over 10 minutes.
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334772
The real problem is the PC doesn't post or boot or talk to the monitor in anyway. I can figure out lighting later. I want to install Windows via my bootable USB I created with Windows 7 pro on it.
The PC does not create an image. I wouldn't need a graphics card plugged in to do so?
I have an i7 6700k plugged in
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334780
5 minutes ago, InsertName said:
Can you hear a beep when you power on? The case led connectors should have been with your front cord umbilicals.
I have not hear any beeps
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334798
5 minutes ago, r3d3mpt10n said:
Are you sure it's not a D0? as far as I'm aware 00 is not used
What does D0 mean?
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334806
HDD LED is a combined connector and not 2 separate connecters, just checked my p400. there shoudl be 3 cables, HDD LED, power switch, reset switch
and if you have it plugged in but the LED does not show then  it is plugged in the wrong way round
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334807
@DutchTexan Are you sure it's the error code "00" that you're getting? Isn't it "D0" or something?
                    PSU Tier List: https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
CPU Celeron n2830 - GPU Integrated - RAM 1x4GB DDR3 1333MHz - Storage 750 GB 5400RPM HDD
                                                Operating System Windows 10 Home
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334808
So all there is to plug in that area are the 3 2 pin connectors? The case lighting doesn't work because I don't have an HDD plugged in?
why does it not boot or post?
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334816
the illumination for the LED in the power button and the Light strip are powered by a SATA poweerr connector
So they do not have power
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334827
What does late CPU initialization mean? That is error code D0
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334831
3 minutes ago, DutchTexan said:
What does D0 mean?
Apparently CPU related. I would remove the cooler, remove CPU, inspect socket, if all is good, reinsert, repaste, reinstall cpu cooler, and try boot up with 1 stick of RAM. If that does not work, try setting up the PC outside the case, on the motherboard box, that would rule out possible shorts
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334845
@DutchTexan Before doing what @r3d3mpt10n said, please try to remove the ram slots and try each one at the time. If that doesn't help, do what r3d3mpt10n said :P
https://linustechtips.com/topic/647905-first-build-help/#findComment-8334856
