Pls help, I need a mousepad.
AIJ
Hello!
I am looking to buy a mousepad that I will use for gaming. I want to spend as less money as possible.
Are there any good, very cheap mousepads with a consistent surface?
Note that I don't need 65billion colors rgb xxxgaming premium x mlg certified mousepads. Just something decent that will give me good feedback.
you have been visited by ascii stephen harper the pc builder
nothing bad will happen to you unless if you post "ignfdofsginedsoignoifdn" in this thread
why? because you'll be banned for spam
lol
Just now, wrathoftheturkey said:
It really doesn't matter, almost anything works
i own a 1$ mousepad rn and its pure garbage
lol
10 minutes ago, AIJ said:
Hello!
https://www.amazon.co.uk/Mouse-HAVIT-Extra-Computer-Gaming/dp/B01F8CIS58/ref=sr_1_3?ie=UTF8&qid=1471982717&sr=8-3&keywords=mousepad+big
I just like long ones :D.
Just now, InsertName said:
Forgot to say in the OP... my workspace is very limited. I need something that takes not too much space.
lol
I would just choose something branded and cheap, like the razer sphex.
I like the Steelseries QcK Heavy, it's pretty big though so you should check dimensions. There's a slightly smaller version of the QcK Heavy called the QcK Mass. They're both 6mm thick. However if you prefer the standard 2 to 3mm thickness, the QcK+ (same dimensions as Heavy) and the QcK (same dimensions as Mass) are good too. You can get the Heavy on Amazon.ca for about 30 bucks canadian. Others should be even cheaper. Other places that are good to look around is NCIX.com and DirectCanada.com. Newegg is alright but most of the time you pay more because of shipping.
QcK Heavy: 450x400x6mm
QcK Mass: 320x270x6mm
QcK+: 450x400x2mm
QcK: 320x270x2mm
