Help With Old Desktops?
4 minutes ago, Brayan2134 said:So, what should I buy? It's a youtube machine that clearly needs no power. I already have the Power supply, and the Graphics card
Well, first off, if nothing graphically intensive is being done I would NOT use the GPU in a new system, there's no reason to waste the electricity/put extra wear and tear on a GPU that's not needed.
Something like a simple Pentium + 8gb of RAM would be sufficient (and even throwing in a cheap 120gb SSD). Although, I would personally go with an i3-6100 + H110 board + 8gb DDR4 + 120GB SSD as the cost difference isn't that much and an i3 is a much more capable CPU.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($110.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard ($53.88 @ OutletPC)
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2133 Memory ($27.99 @ Newegg)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive ($39.99 @ Newegg)
Total: $232.85
Generated by PCPartPicker 2016-08-23 12:35 EDT-0400
