so my gpu has been acting up lately. It has gotten stuck at 50 Mhz on MSI Afterburner. i have uninstalled and reinstalled my drivers 3 times, and it seems to get better but after a a 1-2 hour game session, it goes back to 50 Mhz (From 810 MHz) and i get MASSIVE frame drops. even on lowest settings (in CS:GO) i cant get a solid 20 fps. It kept happening after every driver reinstall after 1-2 hours. GPU is GT 730. Any suggestions? All help is appreciated!
Thanks
Red (Soon to be Retired)CPU: FX-8350 Cooler: CM 212 Evo  GPU: Gigabyte GTX 1060 6GB RAM: 16 GB Kingston HyperX 1866MHz Mobo: Asus M5A97 LE R2.0 SSD: Kingston 128 GB (Boot), Samsung 860 EVO 500 GB (Main Games) HDD: WD Black 1 TB (Storage + Older Games) PSU: EVGA W1 500W Monitor: Dell ST2220l 21.5". Peripherals: Razer Blackwidow Ultimate 2013 Keyboard, Razer Deathadder Mouse, SteelSeries mosepad,
https://linustechtips.com/topic/647481-50-mhz-problem-please-help/
wtf why do you have that gpu? is it getting enough power?
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
my dad gave it to me from his old rig. we are on a tight budget so i couldnt buy a new gpu for my build (going to upgrade to 1060 though). It is getting as much power as Afterburner allows it. 1080 Mv or 1.08 Volts
you may think that it is getting enough but is it showing up on the graphs
what do you mean? on the monitoring charts?
yes is it truly getting what you sent it
what graph do i have to look at? voltage limit? because it says max is 0
Edit: Max is 0
gpu voltage
gpu voltage
let me run cs:go and see if it gives it full voltage
8 minutes ago, GDRRiley said:
gpu voltage
it is only giving it .88 volts
What do i have to do?
that should be fine
that should be fine
it isn't giving it the full 1.08 though. and it was under load while running cs:go
how hot is it
how hot is it
it has been steady in the 30's (Celsius)
maybe not enough power from the mobo. Your cpu overclock could cause that
had to revert my cpu clock because it was unstable. need to edit that in my signature. There is no overclock on the CPU
