so i am wanting to use this https://www.arrow.com/en/products/ckl13efw01/nkk-switches?gclid=CjwKEAjwrcC9BRC2v5rjyvSbhWASJACKkjDzNiARoMwfgEi0VpZAaCbxMYytcFRYeUJ2S_DoTXLWZBoCn6Dw_wcB , and use this http://www.frozencpu.com/products/8699/ele-375/Red_Illuminated_Vandal_Resistant_Latching_Switch_-_22mm_-_Black_Housing_-_Ring_Illumination.html?tl=g44c153 , now an staff member helped me a ton showing me in what line i will set it up, but what adapters/wires will i need to make these work, and i need to know all wires, and for those wondering, i want it to be able to turn they key, allowing the second button to turn on the pc, #pcdeskforlife2020
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/
You will need a cable that goes from the IO connector on the mobo to the switch, any cable with some solder will work
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329785
julian is back!, and also i had another question i was about to ask, where can i find some front panel connecters (io connecter, restart connecter, etc.) and what is solder, i have looked up soldering but couldnt find an answer i understood,
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329787
https://www.amazon.com/HDE-Power-Button-Computer-Switch/dp/B009CWY8PA
this is the cable you need but without the button, you can just chop it off
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329802
ty, not done looking at solder vid, i making an design for the desk-where it all will be, but thanks, and do you have an idea for an idiot like me how i can set it up to where i have to turn this key to allow the button to turn the pc on
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329817
Yeah Ill make a simple diagram
sec
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329823
finished watching video, how do i connect the sodder to the key/button,
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329824
-SNIP-
As mentioned before you will want to wire the switch and key in series, for the connectors unless you have a crimper for dupont terminal that are used for front panel connectors you best bet may be to get some extensions and splice into those to wire up the switches.
-Please refrain from making multiple posts on the same topic, this has been cover a few times already, keep to the original post-
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329836
understood, your initial comment did help, but i wanted someone elses feedback just in case something went wrong
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329851
Excuse the bad skills lol,
your welcome
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329855
Forgot to add you also need to connect the Button LED to the Power led connector on the mobo
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329858
your welcome
yes this is correct, but how do i do this exactly, in the simplest way possible, this is my first build,  so i know about the base pc stuff, but not about this mod stuff
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329860
@W-L
you will notice that your buttons have some metal terminals underneath. here is a ruff method like I used to make in science class back in the day.
- Cut end button off the button cable ordered on amazon
- Strip the insolation on the 2 cables about 2 cm with a knife
- Start heatting up the soldering iron
- Wrap the positive side of the button to a terminal on the key switch
- Hold the soldering iron up to the terminal and hold the solder up to it too, the solder should melt and make a bond
- Take and extra piece of wire and strip its 2 sides, wrap 1 end around the other terminal of the key switch and repaeat the solering procces without shorting the cable wioth the other terminal
- Take the other side of the cable and solder/attach it to a terminal on the button (dont get confused with the LED power terminal)
- take the other side of the button cabel and solder it to the other terminal of the button (not the led power)
-Wrap all the connections in electrical tape
-Connect the power button connector to the motherboard and test
Message me once this is accomplished and I will guide you with the button led power procces,
Flux is optional and can help (substance placed on the metal connection to help it bond / stick better)
Welcome
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329894
Welcome
ty, i will read it over and over once i have all the parts to do it, rn i dont understand it to much but very specific, and nice,
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329915
Just google the words you dont understand, how old are you though?
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329918
6th grader who is an privelaged white kid who has no sibling so all he does all day is code, go to school, do chores for money (how i am funding this) and computer stuff xD
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329924
So your 11?  what languages do you code?
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329934
1 minute ago, aries757 said:
idk, i dont do much coding, just basic dumb stuff, i made like on or 2 gmod hacks with the help of an few steam friends
You code gmod all day? sounds fun, will love to the see desk once made but please dont make morethreads :P
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329948
i won't, i know every thing i need to know now, and i will make an build log or something to show me setting it up, i am hiring someone to build the desk for me,  to confusing 0.0
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329957
Really? why if you know everyting about PC's?
I think your trying to achieve something too complicated for your current knowledge, I suggest you stick with Tower PC's until you know how to wire up a button....
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329962
i have my mind set on this, i have spent days learning about what i need, mostly on here, but i spent to much time to give up now, :P
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8329968
one last question, would this wire work also? https://www.amazon.com/Switch-Power-Style-Push-Button/dp/B000NWFEZQ/ref=sr_1_fkmr1_3?s=pc&ie=UTF8&qid=1471911558&sr=1-3-fkmr1&keywords=pc+power+case+push+button+cable+5+inch i need it to be long enough.
MF UH BEANS
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8330012
yeah
Elemental
Laptops
https://linustechtips.com/topic/647419-key-security-switch-help/#findComment-8330014
