Hi guys.
I tried to improve the airflow in my case by redoing the cable management (it was bad) but now when I power on my pc, the fans spin for half a second, turn off for half a second and turn back on and the pc continues to boot fine.
I didn't have this before and the pc works fine.
What I did:
I turned the PSU upside down (fan was pointing up) because my case supports a bottom PSU fan.
Moved the SSD to the SSD mount on the other side of the motherboard, I don't know why it wasn't there in the first place.
Reseated the GPU.
Reseated the CPU cooler which came loose for some reason while I was busy. (stock intel cooler)
I replugged all the cables into the motherboard.
When I powered on the pc it didn't boot because I forgot the CPU power cable (very stupid) but after I plugged it in it worked fine, except for the problem stated above.
I have also noticed some random stuttering while watching videos on youtube. (not noticed while gaming)
The temperatures are the same as before.
Memtest86: No errors. (4 hours)
Intel Processor Diagnostic Tool: Pass
I don't know if this is a big problem and I don't know what to do about it.
Any help will be appreciated.
PC:
CPU: i7 4770K 3.5ghz (no oc)
Motherboard: Gigabyte GA-Z87-D3HP
RAM: Corsair 1333mhz 16GB (2x8gb)
GPU: MSI R9 290X Gaming 4G
Case: Zalman Z11 Plus HF1
Storage: 120GB SSD + 2TB HDD + 1TB HDD
PSU: Antec NEO ECO 620C (620 watt)
i7 4770K / 16GB RAM 1333mhz / MSI Radeon R9 290X Twin Frozr / Gigabyte GA-Z87-D3HP / 120GB SSD + 2TB HDD / Antec NEO ECO 620C / ZALMAN Z11 PLUS HF1 CASE
https://linustechtips.com/topic/647213-problem-when-powering-up-pc/
Sounds silly but have you triple checked that every cable is securely connected?
I wouldn't say for definite but it sounds like (from the fans and the stuttering) that a contact on a power cable might have been slightly damaged.
Intel i5 6600k @ 4.5GHz | NZXT Kraken X52 | Asus Maximus VIII Hero | Asus ROG Strix GTX 1070 | 16GB DDR4 Corsair Dominator Platinum @ 3200MHz | CoolerMaster MasterCase 5
1 hour ago, Larsie115 said:
Hi guys.
What I did:
Reseated the GPU.
PC:
check the cables over again on the mobo and psu
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
14 minutes ago, Larsie115 said:
You are ABSOLUTELY sure that you plugged every single cable back in correctly?
Other systems I've built:
Yes, also, I used an extension cord for the 8 pin cpu connector but now it's directly attached to the psu. Nothing changed.
