Make programs work again
Go to solution Solved by Naeaes,
Uhhuh. I don't see how you could achieve all this post-humorously. Regardless of where the files for the installed program are located, a portion of it will always reside on the same partition as the operating system. Most common locations are %appdata% C:\Program Files\ C:\ProgramData\ and the Windows registry in addition to the obvious Program Files and Program Files (x86) -folders. Souds to me, you've now lost all or parts of the date you had in there. Hence Windows doesn't know what you preferred programs were, what programs had access to the right-click menus and so on. Heck, as it stands, Windows doesn't even know you have VLC or WinRAR in there. Some of your programs might not even work anymore (possibly blurting errors like can't find .DLL this and .XML that and so on) and some may only lost variables like save states and user preferences.
To counter the effects of this mismatch, you should have migrated the programs. The process involves preparing the programs before the re-install. You now, getting all the relevant data from all over the place into one compressed file and then after reinstalling, un-compressing it all to where it belongs. But by the sound of it, it's too late to migrate. You'd require access to the old OS.
None of this isn't to say that you can't get your settings back via manual registry edits, getting the matching files from the developers or us even and so on. All manually one by one.
Tl;Dr: If I were you, I'd get my re-installing pants on rather now than after hours/days of hunting after fixes to each individual issue.
No the title has nothing to do with what America has to go through but anyway
I recently reinstalled Windows 10 while keeping programs on my other hard drive. All programs remained untouched so I was wondering how to make them "work" again: make them appear in apps & feature but more importantly make me able to extract folders on the left click of a archive file (there are bunch of options for that like Extra here, Extract file... whenever I left click). Playback videos by default using VLC is a problem since I can not pick default app as it is not on the list and I can not choose program (I can do that for every file type but I can change default video playback which will be faster)
I have a lot of programs so I don't feel like reinstalling them
https://linustechtips.com/topic/647210-make-programs-work-again/
you will have to reinstall them all.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/647210-make-programs-work-again/#findComment-8327778
https://linustechtips.com/topic/647210-make-programs-work-again/#findComment-8327805
Here goes 20GB of programs to reinstall... and redownload
https://linustechtips.com/topic/647210-make-programs-work-again/#findComment-8327821
