PC Virus Problems
3 hours ago, AkiTech said:Umm that is why Sir I'm here looking for assistance, how do I fix my pc problem, because I dunno what I'am dealing with..
Well, I can't answer about your Web browsing habits, but downloading things and using unsecured websites can definitely hurt your security. Making sure you have a firewall also helps.
Download Microsoft's anti malware tool. It's built in with Windows 10. Let it do its job. If it doesn't work, and other software doesn't work, you'll probably have to wipe the drive.
Spy Bot Search and Destroy is good. So is AVG. Norton has a deep scanning tool as well. But you need to have two things installed on your PC at all times. 1. Antivirus. 2. AntiMalware.
Have you downloaded anything sketchy? Or fallen for click bait? Java is horribly unsecured, so I try to make sure it's disabled by default.
What have been your online ha it's for the past several weeka. What have you downloaded? Do you pirate content or use cracked .exe files?
