Aquaero!  Their pricey but nothing else like them on the market at the time.  I got a 5LT (one with no screen or pwm) for 45$ on OCN's classifieds.
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/646825-fan-controllers/#findComment-8323782
What fans do you have, how have you been trying to control them, and what headers are you powering them from?
https://linustechtips.com/topic/646825-fan-controllers/#findComment-8333646
Aero cool dead silence red led fans. I had a fan controller, it broke. my fans are 3 pin and I am using 3 pin headers. (MSI Gaming 5 motherboard)
https://linustechtips.com/topic/646825-fan-controllers/#findComment-8334265
I have never seen that one, is it specifically made for like a fish pond or something? I could see me hacking into that with some cool add ons since its fully programmable and I think open source? It could actually be used in quite a lot of different things, I only see the LCD one tho, can u shoot a link to the one u have? Also does the one u have also come with the IR remote?
Rich
https://linustechtips.com/topic/646825-fan-controllers/#findComment-8339466
Rich
Made specifically for watercooling ;) could be used in lots of ways though. The software (aquasuite) is very intuitive and useful. Im no programmer so I know nothing of being able to add on to it, but I imagine it could do just about anything you need it to, as it comes.
There are several versions, the 5lt has only 1 fan pwm circuit (the rest are volts) no screen or ir transmitter, though you can add one on i believe. The 6 has a couple versions too, I think one has a couple extra buttons and comes with the remote.  I'm just getting into the aquaero world so I'm not 100% on any of this info so double check it before you buy!
5LT:
http://www.performance-pcs.com/aquacomputer-aquaero-5-lt-usb-fan-controller.html
https://linustechtips.com/topic/646825-fan-controllers/#findComment-8339670
