Hey,
I'm searching for a 50" TV for my room.
I want to connect it to my pc to use it for gaming, and I also want to hook up a fire TV for watching series and movies.
That's what I will use it for.
I need recommendations on whether to choose 1080p or 4K, and it would be cool, if you could link me some specific products.
My budget is not that specific, but hovers around 550€.
https://linustechtips.com/topic/646809-searching-for-a-tv-need-help/
Doubt you can get a decent 4k TV for 550. Additionally you'll be stuck with 30hz if the tv does not have HDMI 2.0.  So you'll be stuck with a 1080p TV.
Secondly, you will need a TV with low input lag, overal TV's have a fairly high input lag. This mainly depends on yourself, whether you think it is annoying or not. With my LG UF675V I think the input lag is a big annoyance, and the input lag is 54ms as far I know.
So, look for a 1080p TV with low input lag and good refresh rate. Picture quality etc is up to you to decide. (Do not have a specific product to provide at the moment)
Your average Software Engineering student.
