2 minutes ago, dav said:
how do i move my user directory from my ssd where i have windows installed to my hdd?
is it possible to just drag&drop?
https://linustechtips.com/main/topic/629590-windows-10-wont-reset/#comment-8131454
I edit my posts a lot.
https://linustechtips.com/topic/646651-system-folders-combined/#findComment-8296418
11 minutes ago, dav said:
i did it, but my ssd is still full, so which files should i drag and drop? the whole users folder?
When you do the location thing in the file explorer, it should give you an option to move what's already in the folder.
https://linustechtips.com/topic/646651-system-folders-combined/#findComment-8296510
now it says users, but my user isn't in that folder, nor in the hdd, but my files are there. :/ that how it is supposed to be?
https://linustechtips.com/topic/646651-system-folders-combined/#findComment-8296564
5 minutes ago, MrDrWho13 said:
I've no idea how you managed that. You might as well move the videos into the videos folder manually.
even better, the folders are now mixing, so i have 2 identical folders, with both downloads and videos, they both have the download icon
https://linustechtips.com/topic/646651-system-folders-combined/#findComment-8296902
I honestly have no idea how you did that. Maybe you want to move all the folders into a new folder, then start again from the beginning.
https://linustechtips.com/topic/646651-system-folders-combined/#findComment-8296906
Just now, dav said:
i think mt video file was placed inside my download file, and when i removed the vid file from download it happened
https://linustechtips.com/topic/646651-system-folders-combined/#findComment-8296917
I really can't see where in those instructions you could merge two folders. Could you say, step by step, what you're doing?
well, when i download a file a new file named videos is made on my previously used drive, and it's called videos, i have 3 files called videos now, and 1 of them has the download icon
https://linustechtips.com/topic/646651-system-folders-combined/#findComment-8297002
