Hi , today i started my first build everyting was going right but when i start the pc it dosent post, everyting works fine , the fans are spinning, the lights are turned on but 0 signal form the pc
SPECS:
AMD 8370
MSI 970 GAMING
HYPER X FURY 1600 MHZ
RX 480
http://imgur.com/a/r5Zpm
thats the imgur album with all the photos of my build
HELP PLS
I READ THE THREAD  https://linustechtips.com/main/topic/42440-readme-how-to-respond-to-a-no-post-or-no-power-up-situation/ BUT I DONT HAVE ANOTHER PC TO START TESTING ALL THE PARTS.
https://linustechtips.com/topic/646452-pc-dosent-post/
Be sure your display is plugged into everything correctly. Be sure you have plugged everything in. If that fails, your MOBO should be displaying an error code. If so, look it up to see what it means. Try plugging your display cable into your motherboard instead of your graphics card, since you don't have drivers.
https://linustechtips.com/topic/646452-pc-dosent-post/#findComment-8318889
1 minute ago, Foko said:
The cable Vga is connected directly to the psu
It's not. Only the CPU and 24 pin cables are non-renewable on that power supply. You need to plug in the pci-e cable to the power supply.
CPU: i7 4770K  |  Corsair H80i  |  ASUS Z87-Pro  |  8GB Corsair 1866Mhz  |  GPU: MSI Gaming X RX 480 8GB  |  Corsair HX  750
https://linustechtips.com/topic/646452-pc-dosent-post/#findComment-8318918
Just now, Magikarpdrowned said:
I'm sorry, your VGA cable is in your PSU? How the Hell did you manage that?
well i dont know how to explain it , the psu has a vga cable that comes from inside to outside and the outside has the 8 pin conector that is connected to the vga
https://linustechtips.com/topic/646452-pc-dosent-post/#findComment-8318921
Hi! I made a guide for this and you can find it in my signature.
We should honestly sticky a guide for basic desktop troubleshooting on the troubleshooting forum.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/646452-pc-dosent-post/#findComment-8318932
is your psu switched on
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/646452-pc-dosent-post/#findComment-8318968
Well, TV's can be weird in handling a computer signal. But what is the power supply cable on the right in the first photo that is just by the edge of the case?
https://linustechtips.com/topic/646452-pc-dosent-post/#findComment-8319021
it was a pcie cable that i was testing. because the modular psu cames with 3 of those cables
https://linustechtips.com/topic/646452-pc-dosent-post/#findComment-8319029
OK. And what's the power supply?
https://linustechtips.com/topic/646452-pc-dosent-post/#findComment-8319050
