Case Fans
Go to solution Solved by Mobby Dick,
Usually you can choose what connector you want to use.
They do this because some (or rather most) people hate molex, but also some low-end mobos don't have many fan connectors.
So both should work fine for you, just use the one that makes less work :)
25 minutes ago, OnePennyRaptor said:
I recently bought a case for my first build and the case Fans that came with have 3 pin and molex connectors but, they also have leds in them. Do I have to use the 3 pin and the molex to power both or is molex for the led and the 3 pin for the fan??? Please help.
the 3 pin should be able to power the fan and the LED, try it.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/645728-case-fans/#findComment-8311249
