So i replaced my G3258 on to new I5 4590. FIrst day all was okay. But next day while working in After Effects my screen went black. Then it showed 9 times that my monitor was disconnected. Then loaded up my desktop. But it was black. Then started freezing every 10s. Then i closed my PC.( By holding down power button ). When i started pc i went to BIOS to check if something was changed but all was fine. Restarted and then windows started repairing my Hard Drive. What could do this. Mybe i have to install something For I5 and delete G3258 drivers? Right now everything is running normal...
https://linustechtips.com/topic/644709-problems-after-changing-cpu/
What are your CPU temps? Perhaps when you changed the CPU you didn't put the cooler on properly.
Main System Specs:
  • Intel Core i5 6500 3.2GHz CPU
  • Gigabyte GA-H170-D3H Motherboard
  • Kingston HyperX Fury 16GB 2400MHz, Gskill Ripjaws 8GB
  • Asus GTX 1060 Turbo
  • Kingston HyperX Savage 240GB SSD
  • Seagate 1TB NAS Grade HDD x2
  • Thermaltake NiC F3 Cooler
  • EVGA Supernova 750 G2 Power Supply
  • NZXT S340 Red/Black Case
  • Noctua NF-F12 Fan x2
Laptop Specs:
  • Intel Pentium N3700 CPU
  • 4GB Kingston RAM
  • Intel HD Graphics
  • Windows 10 Home
Peripherals:
  • Microsoft Wired 600 KB
  • Dell 2003 Mouse
  • HP Compaq LA2206x Monitor
  • Logitech X530 5.1 Speakers
  • Roland RH-5 Headphones
