So recently I've been playing Doom and No Man's Sky. Maxed out, both games run completely fine at 60 fps (with slight drops into the low 50's in NMS.)
But after a random length of time, my frame rate will suddenly drop to 9-10fps and remain their until I quit. Both games (unless I'm mistaken) are Open GL, maybe that's related somehow? Every other game I play never has this issue, so it's the only correlation I can make. GPU usage I think also drops when my frames tank, so I believe it to be software/driver related.
Any ideas?
Ryzen 7800x3D | Asus ROG STRIX B650E-F | G.Skill Trident Z Neo 2x16gb 6000MHz | ASUS TUF GAMING RTX 4080 Super | Samsung 980 Pro 2tb | Corsair RM850x
https://linustechtips.com/topic/644692-frame-rate-issues/
How are your temps?
Also, just reinstall the Drivers, might work. Use DDU if you want to make sure.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/644692-frame-rate-issues/#findComment-8300171
Try using the experimental patch for NMS, seems to have helped a few people.
CPU: i7 4790K @ 4.5ghz | Mobo: Asus B85MG | RAM: Corsair Vengence 16GB 1600Mhz | GPU: R9 390X
SSD: Kingston 240GB | PSU: Corsair CXM 600W | Case: CIT Dominator + 6 Corsair AF120 Fans all around |
CPU Cooler: Cooler Master TX3 | Monitor: BenQ XL2730z 144Mhz 1440p |
Keyboard: Corsair STRAFE | Mouse: Razer DeatherAdder Chroma
https://linustechtips.com/topic/644692-frame-rate-issues/#findComment-8300643
