chill the fuck out pls.
How big are your UW? there are 25" ones so yeah, there also are triple Mounts.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/644630-vesa-mount/#findComment-8299339
5 minutes ago, SirBatsy said:
Is their VESA mount for triple ultrawide. I NEEEEED THE SPACE UNDER MY MONITOR
Depends on the size of the ultrawides, I'd recommend going with three individual monitor arms if doing triple ultrawides.
https://linustechtips.com/topic/644630-vesa-mount/#findComment-8299344
this is what jayztwocents uses and a alot of other people and that can support 3 predator widescreen monitors.
http://ergotechgroup.com/gaming.html
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
https://linustechtips.com/topic/644630-vesa-mount/#findComment-8299401
