2 monitor stand help
Dr.DUKE
I just picked up a LG 34in ultra wide monitor I'm currently using a asus 27in monitor and what to put them on a dull monitor stand but the ones that come up when I search are for 27in I have seen different size monitors on YouTube but not sure what they are using to support them I want to be able to rotate them if I can is there any out there that can do this thanks for the help
34 is the curveball in this entire mess. I had the same problem and went through 3 stands before i said eff it and went with a 1over 2 set up. Most monitors stands, despite claiming being able to support the weight, cant actually support the 34" weight at all. If you want full articulation and rotation, i recommend getting an individual arm for each monitor and getting the beefiest one you can afford for the 34"
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
OK cool I'll look into that and I wouldn't mind if the 27in was on top of the 34
https://www.amazon.com/gp/aw/d/B00B1D03GQ/ref=mp_s_a_1_6?ie=UTF8&qid=1471385081&sr=8-6&pi=AC_SX236_SY340_FMwebp_QL65&keywords=vivo+triple+monitor+stand&dpPl=1&dpID=31bWc3lb9BL&ref=plSrch
Thats what i ended up getting. Maybe theres a dual monitor version of the same stand.
